A misleading message is sometimes displayed on the device on which you initiated the init state transition when administering a system using the init command even though you executed the reboot command. When executing init s, a single-user shell is established on a remote console and the subsequent rebooting of the system can cause the following message to be displayed:
Enter run level |
Workaround: Ignore the misleading message.
