NAME | Description | Attributes | See Also
Syntax |
duration |
Default value |
30 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the polling interval. If a connection is found to be down, the availability monitor polls the connection at this interval to detect its recovery.
The duration is expressed in seconds.
The value of this property must be at least 1.
The value of this property cannot be unlimited.
This property is used to configure the following features: ldap-data-source.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
