Oracle Fusion Middleware Administration Guide for Oracle Directory Server Enterprise Edition
Interoperation with Java Specification Request (JSR) Based Web Service Clients
By default, JSR clients do not preemptively pass the HTTP Basic Authorization header in requests when the Oracle Web Services Manager (OWSM) oracle/wss_http_token_client_policy policy is configured. The Oracle Directory Server Enterprise Edition DSML web service does not request this authorization header from the client. Therefore, a client that is willing to use HTTP basic authentication must be configured to preemptively stash the header in the initial request. You can achieve this by setting the ClientConstants.PREEMPTIVE_BASIC_AUTH property to true in the request context.
The OWSM oracle/wss_http_token_over_ssl_client_policy policy includes timestamps in the SOAP header by default. These timestamps are not supported by Oracle Directory Server Enterprise Edition, so you must set the orasp:include-timestamp attribute to false in the policy description. For example:
<orasp:require-tls orasp:include-timestamp="false"/>
