Name | Description | Attributes | See Also
Syntax |
enumeration |
Default value |
proportional |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
Yes |
This property specifies the algorithm that determines how operations are distributed to the data sources attached to a data source pool.
This property can take the following values in addition to the default.
Requests are distributed exclusively to the data source with the highest weight. If that data source fails, requests are distributed exclusively to the data source with the next highest weight.
Requests are distributed to the data source with the highest weight until the data source approaches its saturation level. Requests are then sent to the data source with the next highest weight .
When the data source with the highest weight drops below its saturation level, Directory Proxy Server resumes sending requests to that data source.
Requests are distributed to data sources in proportion to the weight of a data source and its cumulative load.
Requests are allocated a hash value according to the type of the request and the properties of the request. Hash values are allocated to data sources in proportion to the weight of a data source and its cumulative load.
This property is used to configure the following features:
One or more data sources are attached to a data source pool for load balancing and failover.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
