Skip Navigation Links
Exit Print View
Oracle Solaris Cluster 3.3 With Sun StorEdge 6130 Array Manual
search filter icon
search icon
Document Information
Preface
1.  Restrictions and Requirements
2.  Installing and Configuring a Sun StorEdge 6130 Array
Installing Storage Arrays
Storage Array Cabling Configurations
How to Install Storage Arrays in a New Cluster
Install and Cable the Hardware
Install the Oracle Solaris Operating System and Configure Multipathing
How to Add Storage Arrays to an Existing Cluster
Configuring Storage Arrays
How to Create a Logical Volume
How to Remove a Logical Volume
3.  Maintaining a Sun StorEdge 6130 Array
Index
This section contains the procedures listed in Table 2-1.
Table 2-1 Task Map: Installing Storage Arrays
Task
Information
Install a storage array in a new cluster, before the OS and Oracle Solaris Cluster software are installed.
Add a storage array to an existing cluster.
You can install your storage array in several different configurations: Figure 2-1 and Figure 2-2 are two examples.
Figure 2-1 Direct-Connect Configuration
image:Illustration: Each node has 2 connections to the service panel. These 2 connections reside on both I/O boards.
Figure 2-2 Switch Configuration
image:Illustration: Each node connects to 2 switches. Each switch has 2 connections to service panel. Switch connections reside on both I/O boards.
Use this procedure to install a storage array in a new cluster. To add a storage array to an existing cluster, use the procedure in How to Add Storage Arrays to an Existing Cluster.
This procedure relies on the following assumptions:
  1. Unpack, place, and level the storage array.
    For instructions, see the Sun StorEdge 6130 Array Getting Started Guide. For a list of StorEdge documentation, see Table P-2.
  2. (Optional) Install the Fibre Channel (FC) switch for the storage array if you do not have a switch installed.
    For the procedure about how to install an FC switch, see the documentation that shipped with your FC switch hardware.
  3. Connect the nodes to the service processor panel.
    • (SAN Configuration) Connect the FC switches to the service processor panel.
    • (Direct-Attached Configuration) Connect each node to the host ports on the array.
  4. Install the storage array.
  5. Power on the storage array and the nodes.
See Also
Use this procedure to add a new storage array to a running cluster. To install a new storage array in a Oracle Solaris Cluster configuration that is not running, use the procedure in How to Install Storage Arrays in a New Cluster.
Before You Begin
See Also
