Sun OpenSSO Enterprise 8.0 Administration Guide
ProcedureTo Modify a Circle of Trust Profile
Follow this procedure to edit the configured General attributes of an existing circle of trust, or to add providers to it. The starting point is Circle of Trust under the Federation interface.
  1. Click the name of a configured circle of trust to modify its profile, or to add providers to it.
    The Edit Circle of Trust page is displayed.
  2. Type new values or edit existing values for the circle of trust's General attributes:
    Name
    The static value of this attribute is the name provided when you created the circle of trust.
    Description
    The value of this attribute is a description of the circle of trust. You may modify the description already entered, if applicable.
    IDFF Writer Service URL
    This attribute specifies the location of the service that writes the common domain cookie. The URL is in the format http://common-domain-host:port/deployment_uri/idffwriter .
    IDFF Reader Service URL
    This attribute specifies the location of the service that reads the common domain cookie. The URL is in the format http://common-domain-host:port/deployment_uri//idffreader .
    SAML2 Writer URL
    This attribute specifies the location of the SAML2 Writer service that writes the cookie to the Common Domain. The URL is in the format http://common-domain-host:port/deployment_uri/saml2writer
    SAML2 Reader URL
    This attribute specifies the location of the SAML2 Writer service that writes the cookie to the Common Domain. The URL is in the format http://common-domain-host:port/deployment_uri/saml2reader
    Status
    The default status is Active. Selecting Inactive disables communication within the circle of trust.
  3. Choose one or more of the available providers and click the Add arrow to select them.
    The list provided contains the names of entities that have been created and populated with providers. For more information, see To Add Providers to a Circle of Trust.
  4. Click Save to complete the operation.
