System Administration Guide: Basic Administration
Modify User Accounts
Unless you define a user name or UID number that conflicts with an existing one, you should never need to modify a user account's login name or UID number. Use the following steps if two user accounts have duplicate user names or UID numbers:
If you do use the Users Tool to change a user name, the home directory's ownership is changed (if a home directory exists for the user).
One part of a user account that you can change is a user's group memberships. Select Properties from Users Tool's Action menu to add or delete a user's secondary groups. Alternatively, you can use the Groups Tool to directly modify a group's member list.
You can also modify the following parts of a user account:
