System Administration Guide: Basic Administration
User ID Numbers
Associated with each user name is a user identification (UID) number. The UID number identifies the user name to any system on which the user attempts to log in, and it is used by systems to identify the owners of files and directories. If you create user accounts for a single individual on a number of different systems, always use the same user name and user ID. In that way, the user can easily move files between systems without ownership problems.
UID numbers must be a whole number less than or equal to 2147483647. They are required for both regular user accounts and special system accounts. The following table lists the UID numbers reserved for user accounts and system accounts.
Table 4–1 Reserved UID Numbers
User ID Numbers
User/Login Accounts
Description
0 - 99
root, daemon, bin, sys, etc.
System accounts
100 - 2147483647
Regular users
General purpose accounts
60001 and 65534
nobody and nobody4
Anonymous users
60002
noaccess
Non-trusted users
Although UID numbers 0 through 99 are reserved, you can add a user with one of these numbers. However, do not use them for regular user accounts. By definition, root always has UID 0, daemon has UID 1, and pseudo-user bin has UID 2. In addition, you should give uucp logins and pseudo user logins, like who, tty, and ttytype, low UIDs so they fall at the beginning of the passwd file.
As with user (login) names, you should adopt a scheme to assign unique UIDs. Some companies assign unique employee numbers, and administrators add a number to the employee number to create a unique UID number for each employee.
To minimize security risks, you should avoid reusing the UIDs from deleted accounts. If you must reuse a UID, “wipe the slate clean” so the new user is not affected by attributes set for a former user. For example, a former user might have been denied access to a printer by being included in a printer deny list, but that attribute might not be appropriate for the new user.
Using Large User IDs and Group IDs
UIDs and GIDs can be assigned up to the maximum value of a signed integer, or 2147483647.
However, UIDs and GIDs over 60000 do not have full functionality and are incompatible with many Solaris features, so avoid using UIDs or GIDs over 60000.
The following table describes interoperability issues with Solaris products and previous Solaris releases.
Table 4–2 Interoperability Issues for UIDs/GIDs Over 60000
Category
Product/Command
Issues/Cautions
NFSTM Interoperability
SunOSTM 4.0 NFS software and compatible versions
NFS server and client code truncates large UIDs and GIDs to 16 bits. This can create security problems if SunOS 4.0 and compatible machines are used in an environment where large UIDs and GIDs are being used. SunOS 4.0 and compatible systems require a patch.
Name Service Interoperability
NIS name service and file-based name service
Users with UIDs above 60000 can log in or use the su command on systems running the Solaris 2.5 and compatible versions, but their UIDs and GIDs will be set to 60001 (nobody).
NIS+ name service
Users with UIDs above 60000 are denied access on systems running Solaris 2.5 and compatible versions and the NIS+ name service.
Table 4–3 Large UID/GID Limitation Summary
UID or GID
Limitations
60003 or greater
  • Users in this category logging into systems running Solaris 2.5 and compatible releases and the NIS or files name service get a UID and GID of nobody.
65535 or greater
  • Solaris 2.5 and compatible releases systems running the NFS version 2 software see UIDs in this category truncated to 16 bits, creating possible security problems.
  • Users in this category using the cpio command (using the default archive format) to copy file see an error message for each file and the UIDs and GIDs are set to nobody in the archive.
  • SPARC based systems: Users in this category running SunOS 4.0 and compatible applications see EOVERFLOW returns from some system calls, and their UIDs and GIDs are mapped to nobody.
  • IA based systems: Users in this category running SVR3-compatible applications will probably see EOVERFLOW return codes from system calls.
  • IA based systems: If users in this category attempt to create a file or directory on a mounted System V file system, the System V file system returns an EOVERFLOW error.
100000 or greater
  • The ps -l command displays a maximum five-digit UID so the printed column won't be aligned when they include a UID or GID larger than 99999.
262144 or greater
  • Users in this category using the cpio command (using -H odc format) or the pax -x cpio command to copy files see an error message returned for each file, and the UIDs and GIDs are set to nobody in the archive.
1000000 or greater
  • Users in this category using the ar command have their UIDs and GIDs set to nobody in the archive.
2097152 or greater
  • Users in this category using the tar command, the cpio -H ustar command, or the pax -x tar command have their UIDs and GIDs set to nobody.
