System Administration Guide: Advanced Administration
Example—Viewing ttymon Port Monitor Status
# sacadm -l -p mbmon
PMTAG  PMTYPE  FLGS RCNT STATUS    COMMAND
mbmon  ttymon  -    0    STARTING  /usr/lib/saf/ttymon #TTY Ports a & b
PMTAG
mbmon
Identifies the port monitor name, mbmon.
PMTYPE
ttymon
Identifies the port monitor type, ttymon.
FLGS
Indicates whether the following two flags are set:
d, do not enable the new port monitor, or
x, do not start the new port monitor. There are no flags set in this example.
RCNT
0
Indicates the return count value. A return count of 0 indicates that the port monitor is not to be restarted if it fails.
STATUS
STARTING
Indicates the current status of the port monitor.
COMMAND
/usr/lib/saf ...
Identifies the command used to start the port monitor.
#TTY Ports a & b
Identifies any comment used to describe the port monitor.
