Console services are not managed by the Service Access Controller nor any explicit ttymon administration file. An entry in the /etc/inittab file is used to manage the console port using ttymon in express mode, which is a special ttymon mode that is invoked directly by a command that requires login service.
The default console entry in the /etc/inittab file looks like this:
co:234:respawn:/usr/lib/saf/ttymon -g -h -p "`uname -n` console login: " -T terminal_type -d /dev/console -l console -m ldterm,ttcompat |
co:234:respawn: |
co identifies the entry as the console; 234 identifies the run levels for the action, respawn, which means the console entry should be restarted if it fails or doesn't exist at run levels 2, 3, and 4. |
/usr/lib/saf/ttymon -g -h |
The -g option is used so the correct baud rate and terminal setting can be set on a port and connect to a login service without being preconfigured by the SAC. The -h option forces a line hangup by setting the line speed to zero before setting the default or specified speed. |
-p "`uname -n` console login: |
Identifies the prompt string for the console port. |
-t terminal_type |
Identifies the terminal type of the console. |
The -d option identifies the console device; the -l option identifies the ttylabel in the /etc/ttydefs file. The -m option identifies the STREAMS modules to be pushed. |
