The following example shows output from the ps command when no options are used.
$ ps PID TTY TIME COMD 1664 pts/4 0:06 csh 2081 pts/4 0:00 ps |
The following example shows output from ps -ef. This output shows that the first process that is executed when the system boots is sched (the swapper) followed by the init process, pageout, and so on.
$ ps -ef UID PID PPID C STIME TTY TIME CMD root 0 0 0 Dec 20 ? 0:17 sched root 1 0 0 Dec 20 ? 0:00 /etc/init - root 2 0 0 Dec 20 ? 0:00 pageout root 3 0 0 Dec 20 ? 4:20 fsflush root 374 367 0 Dec 20 ? 0:00 /usr/lib/saf/ttymon root 367 1 0 Dec 20 ? 0:00 /usr/lib/saf/sac -t 300 root 126 1 0 Dec 20 ? 0:00 /usr/sbin/rpcbind root 54 1 0 Dec 20 ? 0:00 /usr/lib/sysevent/syseventd root 59 1 0 Dec 20 ? 0:00 /usr/lib/picl/picld root 178 1 0 Dec 20 ? 0:03 /usr/lib/autofs/automountd root 129 1 0 Dec 20 ? 0:00 /usr/sbin/keyserv root 213 1 0 Dec 20 ? 0:00 /usr/lib/lpsched root 154 1 0 Dec 20 ? 0:00 /usr/sbin/inetd -s root 139 1 0 Dec 20 ? 0:00 /usr/lib/netsvc/yp/ypbind ... root 191 1 0 Dec 20 ? 0:00 /usr/sbin/syslogd root 208 1 0 Dec 20 ? 0:02 /usr/sbin/nscd root 193 1 0 Dec 20 ? 0:00 /usr/sbin/cron root 174 1 0 Dec 20 ? 0:00 /usr/lib/nfs/lockd daemon 175 1 0 Dec 20 ? 0:00 /usr/lib/nfs/statd root 376 1 0 Dec 20 ? 0:00 /usr/lib/ssh/sshd root 226 1 0 Dec 20 ? 0:00 /usr/lib/power/powerd root 315 1 0 Dec 20 ? 0:00 /usr/lib/nfs/mountd root 237 1 0 Dec 20 ? 0:00 /usr/lib/utmpd . . . |
