UID
User ID number.
LOGIN NAME
Login (or user) name
of the user. Identifies a user who has multiple login names.
CPU (MINS)
Amount of time, in minutes, that the user's
process used the central processing unit. Divided into PRIME
and NPRIME (non-prime) utilization. The accounting system's
version of this data is located in the /etc/acct/holidays
file.
KCORE-MINS
A cumulative measure
of the amount of memory in Kbyte segments per minute that a process uses while
running. Divided into PRIME and NPRIME
utilization.
CONNECT (MINS)
Amount of time in minutes, that the a user was logged into the system, or “real
time.” Divided into PRIME and NPRIME
use. If these numbers are high while the # OF PROCS is
low, you can conclude that the user logs in first thing in the morning and
hardly touches the terminal the rest of the day.
DISK BLOCKS
Output from the acctdusg
program, which runs the disk accounting programs and merges the accounting
records (daytacct). For accounting purposes, a block
is 512 bytes.
# OF PROCS
Number of processes
invoked by the user. If large numbers appear, a user might have a shell procedure
that has run out of control.
# OF SESS
Number of times a user logged on to the system.
# DISK SAMPLES
Number of times disk
accounting was run to obtain the average number of DISK BLOCKS.
FEE
Often unused field that represents the total accumulation of units charged
against the user by the chargefee script.
