System Administration Guide: Advanced Administration
System Accounting Components
The accounting software provides C language programs and shell scripts that organize data into summary files and reports. These programs reside in the /usr/lib/acct directories. The accounting reports reside in the /var/adm/acct directory.
Daily accounting can help you perform four types of auditing:
Connect Accounting
Connect accounting enables you to determine:
To provide this information, the system stores:
These records (produced from the output of system programs such as date, init, login, ttymon, and acctwtmp) are stored in the /var/adm/wtmpx file. Entries in the wtmpx file can contain the following information:
Process Accounting
Process accounting enables you to keep track of the following data about each process that runs on your system:
Every time a process terminates, the exit program collects this information and writes it to the /var/adm/pacct file.
Disk Accounting
Disk accounting enables you to gather and format the following data about the files each user has on disks:
This data is collected by the /usr/lib/acct/dodisk shell script at intervals determined by the entry you add to the /var/spool/cron/crontabs/root file. In turn, the dodisk script invokes the acctdisk and acctdusg commands, which gather disk usage by login.
Caution – Caution –
Information gathered by running the dodisk script is stored in the /var/adm/acct/nite/disktacct file. This information is overwritten the next time the dodisk script is run. Therefore, avoid running the dodisk script twice in the same day.
The acctdusg command might overcharge for files that are written randomly, which can create holes in the files. This problem occurs because the acctdusg command does not read the indirect blocks of a file when determining the file size. Rather, the acctdusg command determines the file size by checking the di_size value of the inode.
Calculating User Fees
The chargefee utility stores charges for special services provided to a user, such as file restoration, in the /var/adm/fee file. Each entry in the file consists of a user login name, user ID, and the fee. This file is checked by the runacct script every day and new entries are merged into the accounting records. For instructions on running the chargefee script to bill users, see How to Bill Users.
How Daily Accounting Works
Here is a step-by-step summary of how daily accounting works:
  1. When the system is switched into multiuser mode, the /usr/lib/acct/startup program is executed. The startup program executes several other programs that invoke daily accounting.
  2. The acctwtmp program adds a “boot” record to the /var/adm/wtmpx file. In this record, the system name is shown as the user name in the wtmpx record. The following table summarizes how the raw accounting data is gathered and where it is stored.
    Table 19–1 Raw Accounting Data
    File in /var/adm
    Information Stored
    Written By
    Format
    wtmpx
    Connect sessions
    login, init
    binary
    Changes
    date
    Reboots
    acctwtmp
    Shutdowns
    shutacct
    pacctn
    Processes
    Kernel (when the process ends)
    binary
    turnacct switch (which creates a new file when the old one reaches 500 blocks)
    fee
    Special charges
    chargefee
    ASCII
    acct/nite/disktacct
    Disk space used
    dodisk
    binary
  3. The turnacct script, invoked with the -on option, begins process accounting. Specifically, the turnacct script executes the accton program with the /var/adm/pacct argument.
  4. The remove shell script “cleans up” the saved pacct and wtmpx files left in the sum directory by the runacct script.
  5. The login and init programs record connect sessions by writing records into the /var/adm/wtmpx file. Date changes (using date with an argument) are also written to the /var/adm/wtmpx file. Reboots and shutdowns using the acctwtmp command are also recorded in the /var/adm/wtmpx the.
  6. When a process ends, the kernel writes one record per process, using the acct.h format, in the /var/adm/pacct file.
    Every hour, the cron command executes the ckpacct script to check the size of the /var/adm/pacct file. If the file grows past 500 blocks (default), the turnacct switch command is executed. (The program moves the pacct file to the pacctn file and creates a new one.) The advantage of having several smaller pacct files becomes apparent when you try to restart the runacct script if a failure occurs when processing these records.
  7. The runacct script is executed by the cron command each night. The runacct script processes the accounting files: /var/adm/pacctn, /var/adm/wtmpx, /var/adm/fee, and /var/adm/acct/nite/disktacct, to produce command summaries and usage summaries by user name.
  8. The /usr/lib/acct/prdaily script is executed on a daily basis by the runacct script to write the daily accounting information in the /var/adm/acct/sum/rprtMMDD files.
  9. The monacct script should be executed on a monthly basis (or at intervals you determine, such as the end of every fiscal period). The monacct script creates a report based on data stored in the sum directory that has been updated daily by the runacct script. After creating the report, the monacct script “cleans up” the sum directory to prepare the directory's files for the new runacct data.
What Happens if the System Shuts Down
If the system is shut down using the shutdown command, the shutacct script is executed automatically. The shutacct script writes a reason record into the /var/adm/wtmpx file and turns off process accounting.
