System Administration Guide: Advanced Administration
Examples—Displaying Information About File Size and Disk Space
In the following example, all the file systems listed are locally mounted except for /usr/dist, which is mounted remotely from the system venus.
$ df
/                  (/dev/dsk/c0t0d0s0 ):  287530 blocks    92028 files
/usr               (/dev/dsk/c0t0d0s6 ): 1020214 blocks   268550 files
/proc              (/proc             ):       0 blocks      878 files
/dev/fd            (fd                ):       0 blocks        0 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/var/run           (swap              ):  396016 blocks     9375 files
/tmp               (swap              ):  396016 blocks     9375 files
/opt               (/dev/dsk/c0t0d0s5 ):  381552 blocks    96649 files
/export/home       (/dev/dsk/c0t0d0s7 ):  434364 blocks   108220 files
/usr/dist          (venus:/usr/dist   ):14750510 blocks  2130134 files
In the following example, file system information is displayed in 1024 bytes.
$ df -h
Filesystem             size   used  avail capacity  Mounted on
/dev/dsk/c0t0d0s0      1.9G    58M   1.8G     4%    /
/dev/dsk/c0t0d0s6      2.5G   765M   1.7G     1%    /usr
/proc                    0K     0K     0K     0%    /proc
fd                       0K     0K     0K     0%    /dev/fd
mnttab                   0K     0K     0K     0%    /etc/mnttab
swap                   2.1G    24K   2.1G     1%    /var/run
swap                   2.1G     0K   2.1G     0%    /tmp
/dev/dsk/c0t0d0s5      1.9G    12M   1.8G     1%    /opt
/dev/dsk/c0t0d0s7      1.9G    10K   1.8G     1%    /export/home
Note –
Although /proc and /tmp are local file systems, they are not UFS file systems. /proc is a PROCFS file system, /var/run and /tmp are TMPFS file systems, and /etc/mnttab is a MNTFS file system.
The following example shows a list of all mounted file systems, device names, total 512-byte blocks used, and number of files. The second line of each two-line entry displays the total number of blocks and files allocated for the file system.
$ df -t
                                  total:   385614 blocks    96832 files
                                  total:  2381102 blocks   300288 files
/proc              (/proc             ):        0 blocks      879 files
                                  total:        0 blocks      924 files
                                  total:        0 blocks       72 files
                                  total:        0 blocks        1 files
/var/run           (swap              ):   396112 blocks     9375 files
                                  total:   396112 blocks     9395 files
/tmp               (swap              ):   396112 blocks     9375 files
                                  total:   396128 blocks     9395 files
                                  total:   434382 blocks   108224 files
/usr/dist          (venus:/usr/dist   ): 14750510 blocks  2130134 files
                                  total: 41225162 blocks  2482176 files
