Reason Error Occurred |
How to Fix the Problem |
Someone accidentally copied a file or directory to the wrong location. This also happens when an application crashes and writes a large core file into the file system. |
Log in as superuser and use the ls -tl command in the specific file system to identify which large file is newly created and remove it. For information on removing core files, see How to Find and Delete core Files. |
