System Administration Guide: IP Services
How to Add Addresses (pntadm)
  1. Become superuser or a user assigned to the DHCP Management profile.
  2. Type a command of the following format:
    # pntadm -A ip-address options  network-address
    Refer to the pntadm man page for a list of options you can use with pntadm -A. In addition, Table 10–2 shows some sample pntadm commands that specify options.
    Note –
    You can write a script to add multiple addresses with pntadm. See Example 12–1 for an example.
