System Administration Guide: IP Services
How to Add Options to a DHCP Macro (dhtadm)
  1. Become superuser or a user assigned to the DHCP Management profile.
  2. Type a command of the following format:
    # dhtadm -M -m macroname -e 'option=value'
    For example, to add the ability to negotiate leases, in macro bluenote, type the following command:
    # dhtadm -M -m bluenote -e 'LeaseNeg=_NULL_VALUE'
    Note that if an option does not require a value, you must use _NULL_VALUE as the value for the option.
