System Administration Guide: IP Services
How to Convert the DHCP Data Store (dhcpconfig -C)
  1. Become superuser or a user assigned to the DHCP Management profile.
  2. Type a command of the following format:
    # /usr/sbin/dhcpconfig -C -r resource -p path
    where resource is the data store (such as SUNWbinfiles) and path is the path to the data (such as /var/dhcp).
    Note that if you want to keep the original data (in the old data store) after the conversion, specify the -k option.
