System Administration Guide: IP Services
How to Duplicate an Existing IP Address (DHCP Manager)
  1. Select the Addresses tab.
  2. Select the network where the new IP address is located.
  3. Select the address whose properties you want to duplicate.
  4. Choose Duplicate from the Edit menu.
  5. Change the IP address and client name for the address.
    Most other options should remain the same, but you can change them if necessary.
  6. Click OK.
