System Administration Guide: IP Services
How to Modify DHCP Option Properties (DHCP Manager)
  1. Select the Options tab.
  2. Select the option whose properties you want to change.
  3. Choose Properties from the Edit menu.
    The Option Properties dialog box opens.
  4. Edit the properties as needed.
    See Table 10–3 for information about the properties.
  5. Select Notify Server of Change when you are finished with options.
  6. Click OK.
