System Administration Guide: IP Services
How to Delete Options from a DHCP Macro (dhtadm)
  1. Become superuser or a user assigned to the DHCP Management profile.
  2. Type a command of the following format:
    # dhtadm -M -m macroname -e 'option='
    For example, to remove the ability to negotiate leases in macro bluenote, type the following command:
    # dhtadm -M -m bluenote -e 'LeaseNeg='
    If an option is specified with no value, it is removed from the macro.
