System Administration Guide: IP Services
How to Import Data on a DHCP Server (dhcpconfig -I)
  1. Become superuser on the server to which you want to import the data.
  2. Type a command of the following format:
    # /usr/sbin/dhcpconfig -I filename
    where filename is the name of the file that contains the data exported from the first server.
    Be sure to modify the imported data as described in How to Modify Imported DHCP Data (pntadm, dhtadm)
