Become superuser on the system console.
Logging in remotely exposes security-critical traffic to eavesdropping. Even if you somehow protect the remote login, the total security of the system is reduced to the security of the remote login session.
Follow the instructions from the vendor about how to extract the revoked certificates.
Use the following procedure to add the revoked certificate to the CRL database.
Repeat for every CRL in the revocation list.
