System Administration Guide: IP Services
Implementing IKE Task Map
The ikeadm(1M), ikecert(1M), and ike.config(4) man pages contain useful procedures in their respective Examples sections.
Table 21–3 Implementing IKE Task Map
Task
Description
For Instructions, Go To …
Configure IKE with pre-shared keys
Involves creating a valid IKE policy file and ike.preshared file. IPsec files are also set up before booting the system to use the IKE-generated keys.
How to Configure IKE With Pre-Shared Keys
Refresh pre-shared keys on a running IKE system
Involves checking the IKE privilege level and editing the ipseckeys file with fresh keying material on communicating systems.
How to Refresh Existing Pre-Shared Keys
Add pre-shared keys to a running IKE system
Involves checking the IKE privilege level and running the ikeadm command with fresh keying material on communicating systems.
How to Add New Pre-Shared Keys
Configure IKE with self-signed public key certificates
Involves creating self–signed certificates with the ikecert certlocal -ks command, and adding the public key from a communicating system with the ikecert certdb command.
How to Configure IKE With Self-Signed Public Certificates
Configure IKE with a PKI Certificate Authority
Involves sending output from the ikecert certlocal –kc command to a PKI, and installing the public key, CA, and CRL from the vendor.
How to Configure IKE With Public Keys Signed by a Certificate Authority
Update the CA revocation lists
Involves installing a PKI vendor's CRL with the ikecert certrldb command.
How to Update a Certificate Revocation List
