System Administration Guide: IP Services
ping Command
Use the ping command to find out whether an IP connection exists for a particular host. The basic syntax is:
/usr/sbin/ping host [timeout]
In this syntax, host is the host name of the machine in question. The optional timeout argument indicates the time in seconds for ping to continue trying to reach the machine—20 seconds by default. The ping(1M) man page describes additional syntaxes and options.
When you run ping, the ICMP protocol sends a datagram to the host you specify, asking for a response. ICMP is the protocol responsible for error handling on a TCP/IP network. See ICMP Protocol for details.
ping Command Task Map
Table 4–6 ping Command Task Map
For Instructions, Go To ...
Determine if a host is running
Involves pinging the hostname
Network Databases and nsswitch.conf File
Determine if a host is losing packets
Involves using the -s option of the ping command
How Name Services Affect Network Databases
How to Determine if a Host Is Running
    On the command line, type the following command.
    % ping hostname
    If host hostname is up, this message is displayed:
    hostname is alive
    This message indicates that hostname responded to the ICMP request. However, if hostname is down or cannot receive the ICMP packets, you receive the following response from ping:
    no answer from hostname
How to Determine if a Host Is Losing Packets
If you suspect that a machine might be losing packets even though the machine is running, you can use the s option of ping to try to detect the problem.
    % ping -s hostname
ping continually sends packets to hostname until you send an interrupt character or a timeout occurs. The responses on your screen resemble the following:
PING elvis: 56 data bytes
64 bytes from icmp_seq=0. time=80. ms
64 bytes from icmp_seq=1. time=0. ms
64 bytes from icmp_seq=2. time=0. ms
64 bytes from icmp_seq=3. time=0. ms
----elvis PING Statistics----
4 packets transmitted, 4 packets received, 0% packet loss
round-trip (ms) min/avg/max = 0/20/80
The packet-loss statistic indicates whether the host has dropped packets.
If ping fails, check the status of the network that is reported by ifconfig and netstat, as described in ifconfig Command and netstat Command.
