System Administration Guide: IP Services
Logging Network Problems
If you suspect a routing daemon malfunction, you can log its actions, including all packet transfers when you start up the routed daemon.
How to Log Network Problems
  1. Become superuser.
  2. Create a log file of routing daemon actions by typing the following command at a command-line prompt.
    # /usr/sbin/in.routed /var/logfilename
Caution – Caution –
On a busy network, this command can generate almost continuous output.
