For reasons that involve router reliability, you might not want your hosts to use RDISC. If the automatic selection of RIP rather than RDISC by a host is to work reliably, the routers in the network (particularly those that run RDISC) must also work reliably.
If your routers are not running RDISC and you install a single Solaris router, by default all hosts that are connected to that router rely on that router alone. To have the hosts on that network use the other routers as well, turn off RDISC on the new router.
Task |
Description |
For Instructions, Go To ... |
Turn off ICMP router discovery on the host |
Involves changing the name of the host's in.rdisc file | |
Turn off ICMP router discovery on the router |
Involves changing the name of the router's in.rdisc file |
Become superuser on the host.
Change the name of the host's /usr/sbin/in.rdisc to some other name, such as /usr/sbin/in.rdisc.saved.
Reboot the host.
