System Administration Guide: IP Services
Determining Host Configuration Modes
As a network administrator, you configure TCP/IP to run on hosts and routers (if applicable). You can configure these machines to obtain configuration information from files on the local machine or from files that are located on other machines on the network. You need the following configuration information:
A machine that obtains TCP/IP configuration information from local files operates in local files mode. A machine that obtains TCP/IP configuration information from a remote machine operates in network client mode.
Machines That Should Run in Local Files Mode
To run in local files mode, a machine must have local copies of the TCP/IP configuration files. TCP/IP Configuration Files describes the files. The machine should have its own disk, though this recommendation is not strictly necessary.
Most servers should run in local file mode. This requirement includes the following servers:
Additionally, routers should run in local files mode.
Machines that exclusively function as print servers do not need to run in local files mode. Whether individual hosts should run in local files mode depends on the size of your network.
If you are running a very small network, the amount of work that is involved in maintaining these files on individual hosts is manageable. If your network serves hundreds of hosts, the task becomes difficult, even with the network divided into a number of administrative subdomains. Thus, for large networks, using local files mode is usually less efficient. However, because routers and servers must be self-sufficient, they should be configured in local files mode.
Network Configuration Servers
Network configuration servers are the machines that supply the TCP/IP configuration information to hosts that are configured in network client mode. These servers support three booting protocols:
Network configuration servers can also function as NFS file servers.
If you are configuring any hosts as network clients, then you must also configure at least one machine on your network as a network configuration server. If your network is subnetted, then you must have at least one network configuration server for each subnet with network clients.
Machines That Are Network Clients
Any host that obtains its configuration information from a network configuration server operates in network client mode. Machines that are configured as network clients do not require local copies of the TCP/IP configuration files.
Network client mode simplifies administration of large networks. Network client mode minimizes the number of configuration tasks that you perform on individual hosts. Network client mode assures that all machines on the network adhere to the same configuration standards.
You can configure network client mode on all types of computers. For example, you can configure network client mode on fully standalone systems or dataless machines.
Mixed Configurations
Configurations are not limited to either an all-local-hosts mode or an all-network-client mode. Routers and servers should always be configured in local mode. For hosts, you can use any combination of local and network client mode.
Sample Network
The following figure shows the hosts of a fictitious network with the network number 192.9.200. The network has one network configuration server, the machine sahara. Machines tenere and nubian have their own disks and run in local files mode. Machine faiyum also has a disk, but this machine operates in network client mode.
Finally, the machine timbuktu is configured as a router. The machine includes two network interfaces. The first interface is named timbuktu. This interface belongs to network 192.9.200. The second interface is named timbuktu-201. This interface belongs to network 192.9.201. Both networks are in the organizational domain The domain uses local files as its name service.
Most examples in this chapter use the network that is shown in the following figure.
Figure 4–1 Hosts in a Sample Network
Diagram shows a sample network with one network server that serves four hosts.
