The remaining network databases seldom need to be edited.
The networks database associates network names with network numbers, enabling some applications to use and display names rather than numbers. The networks database is based on information in the /etc/inet/networks file. This file contains the names of all networks to which your network connects through routers.
The Solaris installation program configures the initial networks database. However, if you add a new network to your existing network topology, you must update this database.
The networks(4) man page contains full syntax information for /etc/inet/networks. The man page's basic format follows:
network-name network-number nickname(s) #comment
network-name is the official name for the network.
network-number is the number assigned by the InterNIC.
nickname is any other name by which the network is known.
#comment is any note that you want to append to an entry in the file.
You must maintain the networks file. The netstat program uses the information in this database to produce status tables.
A sample /etc/networks file follows.
#ident "@(#)networks 1.4 92/07/14 SMI" /* SVr4.0 1.1 */ # # The networks file associates Internet Protocol (IP) network # numbers with network names. The format of this file is: # # network-name network-number nicnames . . . # The loopback network is used only for intra-machine communication loopback 127 # # Internet networks # arpanet 10 arpa # Historical ucb-ether 46 ucbether # # local networks eng 193.9.0 #engineering acc 193.9.1 #accounting prog 193.9.2 #programming |
