System Administration Guide: IP Services
ping Command Task Map
Table 4–6 ping Command Task Map
Task
Description
For Instructions, Go To ...
Determine if a host is running
Involves pinging the hostname
Network Databases and nsswitch.conf File
Determine if a host is losing packets
Involves using the -s option of the ping command
How Name Services Affect Network Databases
