System Administration Guide: IP Services
Network Databases and nsswitch.conf File
The network databases are files that provide information that is needed to configure the network. The network databases follow:
As part of the configuration process, you edit the hosts database and the netmasks database, if your network is subnetted. Two network databases, bootparams and ethers, are used to configure machines as network clients. The remaining databases are used by the operating system and seldom require editing.
Although nsswitch.conf file is not a network database, you need to configure this file along with the relevant network databases. nsswitch.conf specifies which name service to use for a particular machine: local files, NIS, NIS+, DNS, or LDAP.
How Name Services Affect Network Databases
The form of your network database depends on the type of name service you select for your network. For example, the hosts database contains, at minimum, the host name and IPv4 address of the local machine and any network interfaces that are directly connected to the local machine. However, the hosts database could contain other IPv4 addresses and host names, depending on the type of name service on your network.
The network databases are used as follows:
Note –
DNS boot and data files do not correspond directly to the network databases.
The following figure shows the forms of the hosts database that is used by these name services.
Figure 5–2 Forms of the hosts Database Used by Name Services
Diagram shows networks running, DNS, NIS, and NIS+, and the associated network databases.
The following table lists the network databases and how they are used by local files, NIS+, and NIS.
Table 5–1 Network Databases and Corresponding Name Service Files
Network Database
Local Files
NIS+ Tables
NIS Maps
hosts
/etc/inet/hosts
hosts.org_dir
hosts.byaddr hosts.byname
ipnodes
/etc/inet/ipnodes
ipnodes.org_dir
ipnodes.byaddr ipnodes.byname
netmasks
/etc/inet/netmasks
netmasks.org_dir
netmasks.byaddr
ethers
/etc/ethers
ethers.org_dir
ethers.byname ethers.byaddr
bootparams
/etc/bootparams
bootparams.org_dir
bootparams
protocols
/etc/inet/protocols
protocols.org_dir
protocols.byname protocols.bynumber
services
/etc/inet/services
services.org_dir
services.byname
networks
/etc/inet/networks
networks.org_dir
networks.byaddr networks.byname
This book discusses network databases as viewed by networks that use local files for name services. Information about the hosts database is in hosts Database. Information about the ipnodes database is in /etc/inet/ipnodes File. Information about the netmasks database is in netmasks Database. Refer to System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP) and System Administration Guide: Naming and Directory Services (FNS and NIS+) for information on network databases correspondences in NIS, NIS+, DNS, and LDAP.
nsswitch.conf File — Specifying Which Name Service to Use
The /etc/nsswitch.conf file defines the search order of the network databases. The Solaris installation program creates a default /etc/nsswitch.conf file for the local machine, based on the name service you indicate during the installation process. If you selected the “None” option, indicating local files for name service, the resulting nsswitch.conf file resembles the following example.
Example 5–4 nsswitch.conf for Networks Using Files for Name Service
# /etc/nsswitch.files:
# An example file that could be copied over to /etc/nsswitch.conf;
# it does not use any naming service.
# "hosts:" and "services:" in this file are used only if the
# /etc/netconfig file contains "switch.so" as a
# nametoaddr library for "inet" transports.
passwd:          files
group:           files
hosts:           files
networks:        files
protocols:       files
rpc:             files
ethers:          files
netmasks:        files
bootparams:      files
publickey:       files
# At present there isn't a 'files' backend for netgroup; the
# system will figure it out pretty quickly,
# and won't use netgroups at all.
netgroup:        files
automount:       files
aliases:         files
services:        files
sendmailvars:    files
The nsswitch.conf(4) man page describes the file in detail. The file's basic syntax is:
database name-service-to-search
The database field can list one of many types of databases that are searched by the operating system. For example, the field could indicate a database that affects users, such as passwd or aliases, or a network database. The parameter name-service-to-search can have the values files, nis, or nis+ for the network databases. The hosts database can also have dns as a name service to search. You can also list more than one name service, such as nis+ and files.
In Example 5–4, the only search option that is indicated is files. Therefore, the local machine obtains security and automounting information, in addition to network database information, from files that are located in its /etc and /etc/inet directories.
Changing nsswitch.conf
The /etc directory contains the nsswitch.conf file that is created by the Solaris installation program. This directory also contains template files for the following name services:
If you want to change from one name service to another, you can copy the appropriate template to nsswitch.conf. You can also selectively edit the nsswitch.conf file, and change the default name service to search for individual databases.
For example, on a network that runs NIS, you might have to change the nsswitch.conf file on network clients. The search path for the bootparams and ethers databases must list files as the first option, and nis. The following example shows the correct search paths.
Example 5–5 nsswitch.conf for a Client on a Network Running NIS
## /etc/nsswitch.conf:#
passwd:        files nis
group:         file nis
# consult /etc "files" only if nis is down.
hosts:         nis    [NOTFOUND=return] files
networks:      nis    [NOTFOUND=return] files
protocols:     nis    [NOTFOUND=return] files
rpc:           nis    [NOTFOUND=return] files
ethers:        files  [NOTFOUND=return] nis
netmasks:      nis    [NOTFOUND=return] files
bootparams:    files  [NOTFOUND=return] nis
publickey:     nis
netgroup:      nis
automount:     files nis
aliases:       files nis
# for efficient getservbyname() avoid nis
services:      files nis
sendmailvars:  files
For complete details on the name service switch, refer to System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP) and System Administration Guide: Naming and Directory Services (FNS and NIS+).
bootparams Database
The bootparams database contains information that is used by machines that are configured to boot in the network client mode. You need to edit this database if your network has network clients. See Configuring Network Clients for procedures. The database is built from information that is entered into the /etc/bootparams file.
The bootparams(4) man page contains complete syntax for this database. The man page's basic syntax is shown in the following example:
machine-name file-key-server-name:pathname
For each network client machine, the entry might contain the following information: the name of the client, a list of keys, the names of servers, and path names.
The first item of each entry is the name of the client machine. Next is a list of keys, names of servers, and path names, separated by tab characters. All items but the first are optional. An example follows.
Example 5–6 bootparams Database
myclient   root=myserver : /nfsroot/myclient  \
swap=myserver : /nfsswap//myclient \
dump=myserver : /nfsdump/myclient
In this example, the term dump=: tells client hosts not to look for a dump file.
Wildcard Entry for bootparams
In most instances, use the wildcard entry when editing the bootparams database to support clients. This entry follows:
*  root=server:/path dump=:
The asterisk (*) wildcard indicates that this entry applies to all clients that are not specifically named within the bootparams database.
ethers Database
The ethers database is built from information that is entered into the /etc/ethers file. This database associates host names to their Ethernet addresses. You need to create an ethers database only if you are running the RARP daemon. That is, you need to create this database if you are configuring network clients.
RARP uses the file to map Ethernet addresses to IP addresses. If you are running the RARP daemon in.rarpd, you need to set up the ethers file and maintain this file on all hosts that are running the daemon to reflect changes to the network.
The ethers(4) man page contains complete syntax information for this database. The man page's basic format follows:
Ethernet-address hostname #comment
Ethernet-address is the Ethernet address of the host.
hostname is the official name of the host.
#comment is any note that you want to append to an entry in the file.
The equipment manufacturer provides the Ethernet address. If a machine does not display the Ethernet address when you power up, see your hardware manuals for assistance.
When adding entries to the ethers database, ensure that host names correspond to the primary names in the hosts and ipnodes databases, not to the nicknames, as follows.
Example 5–7 Entries in the ethers Database
8:0:20:1:40:16  fayoum
8:0:20:1:40:15  nubian
8:0:20:1:40:7   sahara    # This is a comment
8:0:20:1:40:14  tenere
Other Network Databases
The remaining network databases seldom need to be edited.
networks database
The networks database associates network names with network numbers, enabling some applications to use and display names rather than numbers. The networks database is based on information in the /etc/inet/networks file. This file contains the names of all networks to which your network connects through routers.
The Solaris installation program configures the initial networks database. However, if you add a new network to your existing network topology, you must update this database.
The networks(4) man page contains full syntax information for /etc/inet/networks. The man page's basic format follows:
network-name network-number nickname(s) #comment
network-name is the official name for the network.
network-number is the number assigned by the InterNIC.
nickname is any other name by which the network is known.
You must maintain the networks file. The netstat program uses the information in this database to produce status tables.
A sample /etc/networks file follows.
Example 5–8 /etc/networks File
#ident	"@(#)networks	1.4	92/07/14 SMI"	/* SVr4.0 1.1	*/
# The networks file associates Internet Protocol (IP) network
# numbers with network names. The format of this file is:
# 	network-name		 	 network-number		 	 nicnames . . .
# The loopback network is used only for intra-machine communication
loopback		 	 127
# Internet networks
arpanet     10	   arpa  # Historical
ucb-ether   46	   ucbether
# local networks
eng   193.9.0  #engineering
acc   193.9.1  #accounting
prog  193.9.2  #programming
protocols Database
The protocols database lists the TCP/IP protocols that are installed on your system and their numbers. The Solaris installation program automatically creates the database. This file seldom requires any administration.
The protocols database contains the names of the TCP/IP protocols that are installed on the system. The protocols(4) man page describes the syntax of this database. An example of the /etc/inet/protocols file follows.
Example 5–9 /etc/inet/protocols File
# Internet (IP) protocols
ip    0   IP    # internet protocol, pseudo protocol number
icmp  1   ICMP  # internet control message protocol
tcp   6   TCP   # transmission control protocol
udp  17   UDP   # user datagram protocol
services Database
The services database lists the names of TCP and UDP services and their well-known port numbers. This database is used by programs that call network services. The Solaris installation automatically creates the services database. Generally, this database does not require any administration.
The services(4) man page contains complete syntax information. An excerpt from a typical /etc/inet/services file follows.
Example 5–10 /etc/inet/services File
# Network services
echo      7/udp
echo      7/tcp
discard   9/udp     sink null
discard   11/tcp
daytime   13/udp
daytime   13/tcp
netstat   15/tcp
ftp-data  20/tcp
ftp       21/tcp
telnet    23/tcp
time      37/tcp    timeserver
time      37/udp    timeserver
name      42/udp    nameserver
whois     43/tcp    nickname
