System Administration Guide: IP Services
Designing Your IPv4 Addressing Scheme
After you receive your network number, you can then plan how to assign the host parts of the IPv4 address.
The following table shows the division of the IPv4 address space into network and host address spaces. For each class, “Range” specifies the range of decimal values for the first byte of the network number. “Network Address” indicates the number of bytes of the IPv4 address that are dedicated to the network part of the address. Each byte is represented by xxx. “Host Address” indicates the number of bytes that are dedicated to the host part of the address. For example, in a class A network address, the first byte is dedicated to the network, and the last three bytes are dedicated to the host. The opposite designation is true for a class C network.
Table 3–1 Division of IPv4 Address Space
Class
Range
Network Address
Host Address
A
0–127
xxx
xxx.xxx.xxx
B
128–191
xxx.xxx
xxx.xxx
C
192–223
xxx.xxx.xxx
xxx
The numbers in the first byte of the IPv4 address define whether the network is class A, B, or C. InterNIC assigns the numbers. The remaining three bytes have a range from 0–255. The numbers 0 and 255 are reserved. You can assign the numbers 1–254 to each byte, depending on the network number that is assigned to you.
The following table shows which bytes of the IPv4 address are assigned to you. The following table also shows the range of numbers within each byte that are available for you to assign to your hosts.
Table 3–2 Range of Available Numbers
Network Class
Byte 1 Range
Byte 2 Range
Byte 3 Range
Byte 4 Range
A
0–127
1–254
1–254
1–254
B
128–191
Preassigned by Internet
1–254
1–254
C
192–223
1–254
