System Administration Guide: IP Services
Selecting a Name Service
The Solaris operating environment gives you the option of using four types of name services: local files, NIS, NIS+, and DNS. Name services maintain critical information about the machines on a network, such as the host names, IP addresses, Ethernet addresses, and so forth. The Solaris operating environment also gives you the option of using the LDAP directory service.
Network Databases
When you install the operating system, you supply the host name and IP address of your server, clients, or standalone system as part of the procedure. The Solaris installation program enters this information into the hosts and ipnodes network databases. These databases are part of a set of network databases that contain information necessary for TCP/IP operation on your network. The name service that you select for your network reads these databases.
The configuration of the network databases is a critical. Therefore, you need to decide which name service to use as part of the network planning process. Moreover, the decision to use name services also affects whether you organize your network into an administrative domain. Network Databases and nsswitch.conf File has detailed information on the set of network databases.
Using NIS, NIS+, or DNS for Name Service
The NIS, NIS+, or DNS name services maintain network databases on several servers on the network. System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP) and System Administration Guide: Naming and Directory Services (FNS and NIS+) describe these name services. These guides also explain how to configure the databases. In addition, the guides explain the “namespace” and “administrative domain” concepts in detail.
Using Local Files for Name Service
If you do not implement NIS, NIS+, or DNS, the network uses local files to provide name service. The term “local files” refers to the series of files in the /etc directory that the network databases use. The procedures in this book assume you are using local files for your name service, unless otherwise indicated.
Note –
If you decide to use local files as the name service for your network, you can set up another name service at a later date.
Domain Names
Many networks organize their hosts and routers into a hierarchy of administrative domains. If you are using NIS, NIS+, or the DNS name services, you must select a domain name for your organization that is unique worldwide. To ensure that your domain name is unique, you should register the domain name with the InterNIC. If you plan to use DNS, you should register your domain name with the InterNIC.
The domain name structure is hierarchical. A new domain typically is located below an existing, related domain. For example, the domain name for a subsidiary company can be located below the domain of the parent company. If the domain name has no other relationship, an organization can place its domain name directly under one of the existing top-level domains.
The following examples show top-level domains:
The name that identifies your organization is one that you select, with the provision that the name is unique.
Administrative Subdivisions
The question of administrative subdivisions deals with matters of size and control. The more hosts and servers that you have in a network, the more complex your management task. You might want to handle such situations by setting up additional administrative divisions. Add networks of a particular class. Divide existing networks into subnets. The decision about setting up administrative subdivisions for your network is determined by the following factors:
