System Administration Guide: IP Services
Using Local Files for Name Service
If you do not implement NIS, NIS+, or DNS, the network uses local files to provide name service. The term “local files” refers to the series of files in the /etc directory that the network databases use. The procedures in this book assume you are using local files for your name service, unless otherwise indicated.
Note –
If you decide to use local files as the name service for your network, you can set up another name service at a later date.
