System Administration Guide: IP Services
Routing Protocols
Solaris system software supports two routing protocols: Routing Information Protocol (RIP) and ICMP Router Discovery (RDISC). RIP and RDISC are both standard TCP/IP protocols.
RIP is implemented by in.routed, the routing daemon, which automatically starts when the machine boots. When run on a router with the s option specified, in.routed fills the kernel routing table with a route to every reachable network and advertises “reachability” through all network interfaces.
When run on a host with the q option specified, in.routed extracts routing information but does not advertise reachability. On hosts, routing information can be extracted in two ways:
ICMP Router Discovery (RDISC) Protocol
Hosts use RDISC to obtain routing information from routers. Thus, when hosts are running RDISC, routers must also run another protocol, such as RIP, in order to exchange router information.
RDISC is implemented by in.rdisc, which should run on both routers and hosts. Normally, when in.rdisc runs on a host, in.rdisc enters a default route for each router that is also running in.rdisc. A host that is running in.rdisc cannot discover routers that are running only RIP. Furthermore, when routers are running in.rdisc (rather than in.routed), they can be configured to have a different preference, which causes hosts to select a better router. See the rdisc(1M) man page.
