System Administration Guide: IP Services
Implementing IPsec Task Map
Table 20–1 Implementing IPsec Task Map
For Instructions, Go To …
Secure traffic between two IPv6 systems
Involves adding addresses to the /etc/inet/ipnodes file, entering IPsec policy in the /etc/inet/ipsecinit.conf file, manually adding keys with the ipseckey command, and invoking the ipsecinit.conf file.
How to Secure Traffic Between Two Systems
Secure a Web server by using IPsec policy
Involves enabling only secure traffic by entering different security requirements for different ports in the ipsecinit.conf file, and activating the file.
How to Secure a Web Server
Set up a virtual private network
Involves turning off IP forwarding, turning on IP strict destination multihoming, disabling most network and Internet services, adding security associations, and configuring a secure tunnel. Also involves turning on IP forwarding, configuring a default route, and running the routing protocol.
How to Set Up a Virtual Private Network
Replace current security associations
Involves flushing current security associations and entering new ones on every affected system.
How to Replace Current Security Associations
