If, for example, the /etc/inet/ipsecinit.conf file is sent from an NFS-mounted file system, an adversary can modify the data contained in the file. The outcome would be a change to the configured policy. Consequently, you should use extreme caution if transmitting a copy of the ipsecinit.conf file over a network.
Policy cannot be changed (is “latched”) for TCP/UDP sockets on which a connect(3SOCKET) or accept(3SOCKET) has been issued. Adding new policy entries does not affect the latched sockets. This latching feature might change in the future, so you should not depend on this feature.
Ensure that you set up the policies before starting any communications, because existing connections might be affected by the addition of new policy entries. Similarly, do not change policies in the middle of a communication.
If your source address is a host that can be looked up over the network, and your naming system itself is compromised, then any names that are used are no longer trustworthy.
Security weaknesses often lie in misapplication of tools, not the tools themselves. You should be cautious when using the ipsecconf command. Use a console or other hard-connected TTY for the safest mode of operation.
