When you configure the mipagent.conf file for the first time, you need to perform the following tasks:
Depending on your organization's host's requirements, determine what functionality your Mobile IP agent can provide:
Create the /etc/inet/mipagent.conf file and enter the settings you require by using the procedures that are described in this section. You can also copy one of the following files to /etc/inet/mipagent.conf and modify it according to your requirements:
For foreign agent functionality, copy /etc/inet/mipagent.conf.fa-sample.
For home agent functionality , copy /etc/inet/mipagent.conf.ha-sample.
For both foreign agent and home agent functionality, copy /etc/inet/mipagent.conf-sample.
You can reboot your system to invoke the boot script that starts the mipagent daemon. You can also start mipagent by typing the following command on a command line:
# /etc/inet.d/mipagent start |
The following table provides a brief description of the tasks that are described in this section.
Table 24–1 Configuring the Mobile IP Configuration File Task Map
Task |
Description |
For Instructions, Go to ... |
Creating the Mobile IP configuration file |
Involves creating the /etc/inet/mipagent.conf file or copying one of the sample files | |
Configuring the General section |
Involves typing the version number into the General section of the Mobile IP configuration file | |
Configuring the Advertisements section |
Involves adding labels and values or changing them in the Advertisements section of the Mobile IP configuration file | |
Configuring the GlobalSecurityParameters section |
Involves adding labels and values or changing them in the GlobalSecurityParameters section of the Mobile IP configuration file | |
Configuring the Pool section |
Involves adding labels and values or changing them in the Pool section of the Mobile IP configuration file | |
Configuring the SPI section |
Involves adding labels and values or changing them in the SPI section of the Mobile IP configuration file | |
Configuring the Address section |
Involves adding labels and values or changing them in the Address section of the Mobile IP configuration file |
Become superuser on the system where you want to enable Mobile IP.
Depending on your preference, do one of the following substeps.
Add or change configuration parameters in the /etc/inet/mipagent.conf file to conform to your configuration requirements. The remaining procedures in this section describe the steps that you perform.
If you copied one of the sample files, you can omit this procedure because the sample file contains this entry.
Edit the /etc/inet/mipagent.conf file and add the following lines.
[General] Version = 1.0 |
The /etc/inet/mipagent.conf file must contain the preceding entry.
General Section provides descriptions of the labels and values that are used in this section.
Edit the /etc/inet/mipagent.conf file and add or change the following lines by using the values that are required for your configuration.
[Advertisements Interface-name] HomeAgent = <yes/no> ForeignAgent = <yes/no> PrefixFlags = <yes/no> AdvertiseOnBcast = <yes/no> RegLifetime = n AdvLifetime = n AdvFrequency = n ReverseTunnel = <yes/no/FA/HA/both> ReverseTunnelRequired = <yes/no/FA/HA> |
You must include a different Advertisements section for each interface on the local host that provides Mobile IP services.
Advertisements Section provides descriptions of the labels and values that are used in this section.
[GlobalSecurityParameters] MaxClockSkew = n HA-FAauth = <yes/no> MN-FAauth = <yes/no> Challenge = <yes/no> KeyDistribution = files |
GlobalSecurityParameters Section provides descriptions of the labels and values that are used in this section.
[Pool Pool-identifier] BaseAddress = IP-address Size = size |
Pool Section provides descriptions of the labels and values that are used in this section.
[SPI SPI-identifier] ReplayMethod = <none/timestamps> Key = key |
You must include a different SPI section for each security context that is deployed.
SPI Section provides descriptions of the labels and values that are used in this section.
For a mobile node, use the following:
[Address address] Type = node SPI = SPI-identifier |
For an agent, use the following:
[Address address] Type = agent SPI = SPI-identifier IPsecRequest = action {properties} [: action {properties}] IPsecReply = action {properties} [: action {properties}] IPsecTunnel = action {properties} [: action {properties}] |
action and {properties} are any action and associated properties that are defined in the ipsec(7P) man page.
The SPI that is configured previously corresponds to the MD5 protection mechanism that is required by RFC 2002. The SPI that is configured previously does not correspond to the SPI that is used by IPsec. For more information about IPsec, see Chapter 19, IPsec (Overview) and Chapter 20, Administering IPsec (Task). Also see the ipsec(7P) man page.
For mobile node that is identified by its NAI, use the following:
[Address NAI] Type = Node SPI = SPI-identifier Pool = Pool-identifier |
For default mobile node, use the following:
[Address Node-Default] Type = Node SPI = SPI-identifier Pool = Pool-identifier |
Address Section provides descriptions of the labels and values that are used in this section.
