System Administration Guide: IP Services
Modifying the Mobile IP Configuration File Task Map
Table 24–2 Modifying the Mobile IP Configuration File Task Map
Task
Description
For Instructions, Go to ...
Modifying the General section
Uses the mipagentconfig change command to change the value of a label in the General section of the Mobile IP configuration file
How to Modify the General Section
Modifying the Advertisements section
Uses the mipagentconfig change command to change the value of a label in the Advertisements section of the Mobile IP configuration file
How to Modify the Advertisements Section
Modifying the GlobalSecurityParameters section
Uses the mipagentconfig change command to change the value of a label in the GlobalSecurityParameters section of the Mobile IP configuration file
How to Modify the GlobalSecurityParameters Section
Modifying the Pool section
Uses the mipagentconfig change command to change the value of a label in the Pool section of the Mobile IP configuration file
How to Modify the Pool Section
Modifying the SPI section
Uses the mipagentconfig change command to change the value of a label in the SPI section of the Mobile IP configuration file
How to Modify the SPI Section
Modifying the Address section
Uses the mipagentconfig change command to change the value of a label in the Address section of the Mobile IP configuration file
How to Modify the Address Section
Adding or deleting parameters
Uses the mipagentconfig add or delete commands to add new parameters, labels, and values or to delete existing ones in any of the sections of the Mobile IP configuration file
How to Add or Delete Configuration File Parameters
Displaying the current settings of parameter destinations
Uses the mipagentconfig get command to display current settings of any section of the Mobile IP configuration file
How to Display Current Parameter Settings in the Configuration File
