System Administration Guide: IP Services
Displaying Mobility Agent Status
You can use the mipagentstat command to display a foreign agent's visitors list and a home agent's binding table. Mobile IP Mobility Agent Status provides a conceptual description of the mipagentstat command. You can also review the mipagentstat(1M) man page.
How to Display Mobility Agent Status
  1. Become superuser on the system where you are enabling Mobile IP.
  2. On a command line, type the following command.
    # mipagentstat <option>
    You can use the following options:
    -f
    Shows the list of active mobile nodes in the foreign agent's visitor list
    -h
    Shows the list of active mobile nodes in the home agent's binding table
    -p
    Shows the list of security associations with an agent's mobility agent peers
For example, to show the visitor list for all mobile nodes that are registered with the foreign agent, use the following command.
# mipagentstat -f
This command causes the following results to be displayed (for example).
Mobile Node     Home Agent     Time (s)     Time (s)  Flags
                               Granted      Remaining
foobar.xyz.com  ha1.xyz.com    600          125       .....T.
10.1.5.23       10.1.5.1       1000         10        .....T.
To show the foreign agent security associations, use the following command.
# mipagentstat -p
Foreign                  ..... Security Association(s).....
Agent                    Requests Replies  FTunnel  RTunnel
forn-agent.eng.sun.com   AH       AH       ESP      ESP
To show the home agent security associations, use the following command.
# mipagentstat -fp
Home                     ..... Security Association(s) .....
home-agent.eng.sun.com   AH       AH       ESP      ESP
ha1.xyz.com              AH,ESP   AH       AH,ESP   AH,ESP
