The following table provides a brief description of the tasks that are described in this section.
Table 24–1 Configuring the Mobile IP Configuration File Task Map
Task |
Description |
For Instructions, Go to ... |
Creating the Mobile IP configuration file |
Involves creating the /etc/inet/mipagent.conf file or copying one of the sample files | |
Configuring the General section |
Involves typing the version number into the General section of the Mobile IP configuration file | |
Configuring the Advertisements section |
Involves adding labels and values or changing them in the Advertisements section of the Mobile IP configuration file | |
Configuring the GlobalSecurityParameters section |
Involves adding labels and values or changing them in the GlobalSecurityParameters section of the Mobile IP configuration file | |
Configuring the Pool section |
Involves adding labels and values or changing them in the Pool section of the Mobile IP configuration file | |
Configuring the SPI section |
Involves adding labels and values or changing them in the SPI section of the Mobile IP configuration file | |
Configuring the Address section |
Involves adding labels and values or changing them in the Address section of the Mobile IP configuration file |
