System Administration Guide: IP Services
How to Configure the General Section
If you copied one of the sample files, you can omit this procedure because the sample file contains this entry.
    Edit the /etc/inet/mipagent.conf file and add the following lines.
         Version = 1.0
Note –
The /etc/inet/mipagent.conf file must contain the preceding entry.
General Section provides descriptions of the labels and values that are used in this section.
