System Administration Guide: IP Services
How to Configure the Advertisements Section
    Edit the /etc/inet/mipagent.conf file and add or change the following lines by using the values that are required for your configuration.
    [Advertisements Interface-name]
         HomeAgent = <yes/no>
         ForeignAgent = <yes/no>
         PrefixFlags = <yes/no>
         AdvertiseOnBcast = <yes/no>
         RegLifetime = n
         AdvLifetime = n
         AdvFrequency = n
         ReverseTunnel = <yes/no/FA/HA/both>
         ReverseTunnelRequired = <yes/no/FA/HA>
Note –
You must include a different Advertisements section for each interface on the local host that provides Mobile IP services.
Advertisements Section provides descriptions of the labels and values that are used in this section.
