System Administration Guide: IP Services
How to Configure the SPI Section
    Edit the /etc/inet/mipagent.conf file and add or change the following lines by using the values that are required for your configuration.
    [SPI SPI-identifier]
         ReplayMethod = <none/timestamps>
         Key = key
Note –
You must include a different SPI section for each security context that is deployed.
SPI Section provides descriptions of the labels and values that are used in this section.
