System Administration Guide: IP Services
How to Modify the General Section
  1. Become superuser on the system where you want to enable Mobile IP.
  2. On a command line, type the following command for each label that you want to modify in the General section.
    # mipagentconfig change <label> <value>
The following example shows how you might change the version number (in the future) in the configuration file's General section.
Example 24–1 Changing Parameters in the General Section
# mipagentconfig change version 2
