Advertisements Section
The Advertisements section contains the HomeAgent and ForeignAgent labels, as well as other labels. You must include a
different Advertisements section for each interface on
the local host that provides Mobile IP services. The Advertisements section has the following syntax:
[Advertisements Interface-name]
HomeAgent = <yes/no>
ForeignAgent = <yes/no>
Typically, your system has a single interface (le0, hme0, and so on) and supports both home agent and foreign agent
operations. If this is the situation for the example hme0,
then the yes value is assigned to both the HomeAgent and ForeignAgent labels as follows:
[Advertisements hme0]
HomeAgent = yes
ForeignAgent = yes
For advertisement over
dynamic interfaces, use '*' for the device id part. For example, Interface-name ppp* actually implies all ppp interfaces that
are configured after mipagent has been started. All the
attributes in the advertisement section of a dynamic interface type remain
the same.
The following table describes the labels and values that you can use
in the Advertisements section.
Table 25–1
Advertisements Section Labels and Values
Label
Value
Description
HomeAgent
yes or no
Determines
if mipagent provides home agent functionality.
ForeignAgent
yes or no
Determines
if mipagent provides foreign agent functionality.
PrefixFlags
yes or no
Specifies
if advertisements include the optional prefix-length extension.
AdvertiseOnBcast
yes or no
If yes, advertisements are sent on 255.255.255.255,
rather than 224.0.0.1.
RegLifetime
n
The maximum lifetime value that is
accepted in registration requests, in seconds.
AdvLifetime
n
The maximum length of time that the
advertisement is considered valid in the absence of further advertisements,
in seconds.
AdvFrequency
n
Time between two consecutive advertisements,
in seconds.
ReverseTunnel
yes or no FA or HA or both
Determines if mipagent provides reverse-tunnel
functionality.
The value yes means that both
the foreign agent and home agent support reverse tunneling. The value no means that the interface does not support reverse tunneling.
The value FA means that the foreign agent
supports reverse tunneling. The value HA means that the
home agent supports reverse tunneling. The value both means
that both the foreign agent and home agent support reverse tunneling.
ReverseTunnelRequired
yes or no
requires reverse tunnel functionality. Consequently, determines if a mobile
node must request a reverse tunnel during registration.
The value yes means that both the foreign agent and home agent require a reverse
tunnel. The value no means that the interface does not
require a reverse tunnel.
The value FA means
that the foreign agent requires a reverse tunnel. The value HA
means that the home agent requires a reverse tunnel.
AdvInitCount
n
Determines initial number of unsolicited advertisements.
The default value is 1. This value is meaningful only if AdvLimitUnsolicited is yes.
AdvLimitUnsolicited
yes or no
Enables or disables a limited number of unsolicited
advertisements over the mobility interface.
