System Administration Guide: IP Services
Mobile Node Identified by its NAI
The Address section for a mobile node that is identified by its NAI contains the Type, SPI, and Pool labels. The NAI parameter enables you to identify mobile nodes through their NAI. The Address section, using the NAI parameter, has the following syntax:
[Address NAI]
     Type = Node
     SPI = SPI-identifier
     Pool = Pool-identifier
In order to use pools, you identify mobile nodes through their NAI. The Address section permits you to configure an NAI, as opposed to a home address. An NAI uses the format user@domain format. You use the Pool label to specify which address pool to use in order to allocate the home address to the mobile node.
The following table describes the labels and values that you can use in the Address section for a mobile node that is identified by its NAI.
Table 25–7 Address Section Labels and Values—Mobile Node Identified by Its NAI
Label
Value
Description
Type
node
Specifies entry for a mobile node
SPI
n
Specifies SPI value for the associated entry
Pool
n
Allocates the pool from which an address is assigned to a mobile node
You must have corresponding SPI and Pool sections for the SPI and Pool labels that are defined in an Address section with a mobile node that is identified by its NAI, as shown in the following illustration.
Figure 25–1 Corresponding SPI and Pool Sections for Address Section With Mobile Node Identified by Its NAI
Shows that an SPI of 251 and POOL of 10 correspond to the same SPI and POOL numbers in the ADDRESS NAI section.
