System Administration Guide: IP Services
Example–mipagent.conf.ha-sample File
The following listing shows the sections, labels, and values that are contained in the mipagent.conf.ha-sample file. Configuration File Sections and Labels describes the syntax, sections, labels, and values. The mipagent.conf.ha-sample file shows a configuration that provides only home agent functionality. Otherwise, this file is the same as the mipagent.conf-sample file.
[General]
   Version = 1.0    # version number for the configuration file. (required)
[Advertisements hme0]
   HomeAgent = yes
   ForeignAgent = no
   PrefixFlags = yes
   AdvertiseOnBcast = yes
   RegLifetime = 200
   AdvLifetime = 200
   AdvFrequency = 5
   ReverseTunnel = yes
   ReverseTunnelRequired = no
[GlobalSecurityParameters]
   MaxClockSkew = 300
   HA-FAauth = yes
   MN-FAauth = yes
   Challenge = no
   KeyDistribution = files
[Pool 1]
   BaseAddress = 10.68.30.7
   Size = 4
[SPI 257]
   ReplayMethod = none
   Key = 11111111111111111111111111111111
[SPI 258]
   ReplayMethod = none
   Key = 15111111111111111111111111111111
[Address 10.1.1.1]
   Type = node
   SPI = 258
[Address mobilenode@sun.com]
   Type = node
   SPI = 257
   Pool = 1
[Address Node-Default]
   Type = node
   SPI = 258
   Pool = 1
[Address 10.68.30.36]
    Type = agent
    SPI = 257
    IPsecRequest = apply {auth_algs md5 sa shared}
    IPsecReply = permit {auth_algs md5}
    IPsecTunnel = apply {encr_algs 3des sa shared}
