System Administration Guide: IP Services
netstat Extensions for Mobile IP
Mobile IP extensions have been added to the netstat(1M) command to identify Mobile IP forwarding routes. Specifically, you can use the netstat(1M) command to display a new routing table that is called “Source-Specific.” See the netstat(1M) man page for more information.
The following example shows the output of netstat when you use the -nr flags.
Example 25–4 Output From netstat Command
Routing Table:   IPv4 Source-Specific
Destination      In If     Source      Gateway Flags  Use  Out If
10.6.32.11      ip.tun1      --      10.6.32.97  UH      0 hme1
    --          hme1    10.6.32.11       --      U       0 ip.tun1
The example shows the routes for a foreign agent that uses a reverse tunnel. The first line indicates that the destination IP address 10.6.32.11 and the incoming interface ip.tun1 select hme1 as the interface that forwards the packets. The next line indicates that any packet that originates from interface hme1 and source address 10.6.32.11 must be forwarded to ip.tun1.
