After a failover, failbacks occurs when the failed interface is repaired. However, in.mpathd does not fail back the interface if FAILBACK is set to no.
As noted in Detecting Physical Interface Failures, automatic failback is supported for physical interfaces that are not present at system boot. See How to Recover a Physical Interface That Was Not Present at System Boot.
